9/8/2010 3:09 PM | |||||
Joined: 9/27/2006 Last visit: 8/5/2024 Posts: 12273 Rating: (2680)
Hello patel; This is how the 416-0XK02 is described in the Industrial Mall,while the 416-2XN05 is slotted as a direct replacement for the outdated CPU.
The following FAQ should reassure you that you can use the newer CPU as a replacement to the older model, without program change, and using the same RAM card: http://support.automation.siemens.com/WW/view/en/25208204 However, if you do no hardware configuration change, you will be limited to the outdated CPU's performance: you will not be able to take advantage of the expanded memory range for example. Hope this helps, Daniel Chartier |
9/9/2010 8:45 AM | |
Posts: 134 Rating: (2) |
HI.. Thanks... Then what can i do if i want to use same RAM module for my Spare cpu? |
