12/19/2016 11:32 AM | |
Joined: 5/12/2006 Last visit: 5/1/2024 Posts: 22243 Rating: (2981) |
Hello, which version of the PLC Firmware you use? From the FAQ: https://support.industry.siemens.com/cs/ww/en/view/7808062 Fault-tolerant CPU (H-CPU) firmware V6.0 and higher with PROFIBUS DP and PROFINET interfaces Regards |
2/8/2017 8:05 AM | |
Hello, from the technical Data of the PLC https://support.industry.siemens.com/cs/ww/en/pv/6ES7412-3HJ14-0AB0/td Routing supported with V4.5 Fw Version.
Christoph |
