7/12/2022 12:32 AM | |
Joined: 9/27/2006 Last visit: 7/31/2024 Posts: 12272 Rating:
Hello Alan; Most often, the CPU blinking all LEDs can be due to one of 2 faults: - a problem in the CPU memory in the on-board RAM ( you should think of having the CPU repaired or replaced) or in the MMC (in which case you should try installing a new one). - you downloaded a defective hardware configuration; this could be what happened in your case. The remedy in this situation requires you do a complete memory reset using the reset switch on the front of the CPU, while the MMC has been removed from the CPU, followed by a download of a corrected hardware configuration. Look at the suggestions in this discussion (one of any similar threads on the forum), they might provide you with a solution. https://support.industry.siemens.com/forum/ca/en/posts/cpu-s7-300-all-leds-blink/145009 Hope this helps, Daniel Chartier |
