1/23/2023 3:59 PM | |
Joined: 3/14/2008 Last visit: 4/26/2024 Posts: 2066 Rating: (928)
Hi, If you have set the time synchronization in the hardware properties of the CPU to: "as slave", then the clock of the CPU would be synchronized by the time master. |
