9/18/2021 10:10 PM | |
Joined: 9/27/2006 Last visit: 5/28/2024 Posts: 12257 Rating: (2668)
Hello omar; You will find the firmware versions for H-CPUs from 6.0.1 in the following download page. https://support.industry.siemens.com/cs/ww/en/view/109474550 If you feel you absolutely need v6.00, or you need confirmation that this should be the procedure in your case, then you should start a Support Reuest (link at the top of this page) and ask Siemens techs directly for this firmware version. Hope this helps, Daniel Chartier |
