2/23/2011 9:44 PM | |
Posts: 947 Rating:
1.CPU4xx not used MMC-card |
2/24/2011 11:16 AM | |
Posts: 947 Rating:
I did not understand the problem: if this is - howto write newfirmware to flash, may be textin the attachement help you. You must work on PG or with external prommer. In control panel windows You must set memory card parameter assigment to your prommer (internal for field Pg)
Attachmentupdate.zip (244 Downloads) |
