4/24/2021 5:52 AM | |
Joined: 1/5/2017 Last visit: 5/1/2024 Posts: 8 Rating:
I want to create 2 data array int array between 2 data blocks but use SLT, data1 is 4 times more than data 2 or follow a program (example db1.dbw0 = 4x db2.dbw0, db1.dbw2 = 4 x db2.dbw2, ......) Is there any way of using such a thing? Thanks you very much! ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 04/26/2021 05:53:26New subject after splitting |
4/26/2021 11:54 AM | |
Joined: 10/10/2005 Last visit: 4/18/2024 Posts: 1917 Rating:
Hello le quoc lam, I'm not sure whether I have understood your problem. But I think you want to copy data from DBx to DBy. There are some examples in the internet with ANY Pointer: How do you parameterize blocks, which have "ANY"-type or "Pointer" type parameters? How can you calculate an offset for an ANY pointer or change the pointer? With best regards |
