2/27/2024 6:18 PM | |
Joined: 3/28/2023 Last visit: 8/17/2024 Posts: 20 Rating:
I am not sure if it's possible to export only the Profibus module from your project, perhaps someone can correct me. This link has documentation for using CPU 1200 as a gateway for PROFINET-PROFIBUS communication, exactly as the way you're doing it. If you communicate your CPU 1200 as I-Device then you can map the data to your Profibus devices. https://support.industry.siemens.com/cs/ca/en/view/101495058 |
