10/30/2020 2:07 PM | |
Joined: 8/3/2009 Last visit: 4/30/2024 Posts: 12869 Rating: (1643)
Hello Which Version of WinCC flexible do you use? If you use WinCC flexible 2008 SP5 then use latest Upd2 https://support.industry.siemens.com/cs/ww/en/view/109757233 It would be good if you show us a Screenshot of where the System stops Bye Murof |
