12/16/2016 7:28 AM | |
Joined: 3/14/2008 Last visit: 7/12/2024 Posts: 2076 Rating:
Hmm, Maybe the "*" sign is not allowed for the PCS7Typicals file. Please rename it to something like: "PCS7TypicalsV8_Duccio" for example and check again.
12/16/2016 10:51 AM | |
Can you add the Block icon log? You can find it under your multiproject: \[OS project]\wincproj\[OS server name]\THPOFile.txt” |
12/16/2016 3:46 PM | |
Well, the error is clear...no more than 10 template files, but did you insert a new template file for each block icon? |
