7/28/2011 11:26 AM | |
Joined: 8/25/2006 Last visit: 4/27/2024 Posts: 2203 Rating: (277)
There are two possibilities to create your own blocks:
For enable/disable some block(s) you need to place it in runtime group and make an interconnection to this runtime group from any binary signal in CFC-program. You may read about this also in the CFC-help 'CFC for SIMATIC TDC/SIMADYN D - Run-time properties - Enable attributes'. But remember that you can't disable some blocks (you can see this property in the help for each block, look for text 'The function block may not be disabled per task group'). Usually these are blocks that begins with @. Also remember that when you disable in such way runtime group, all values at block's outputs will be frozen. |
12/30/2015 9:52 AM | |
Joined: 9/1/2005 Last visit: 3/5/2024 Posts: 4097 Rating: (193) |
New question published by Siro Tonga is split to a separate thread with the subject scalling factor in CFC FM458 . Best regards |
