5/8/2018 4:29 PM | |
Joined: 3/14/2008 Last visit: 7/12/2024 Posts: 2076 Rating:
Please check if the counter is taken from 300elements library. If so, you have a block designed for 300 cpu's and this will not work. You need to take the counter from 400elements indicating blocks designed for 400 cpu's as this is the case for PCS7. |
