9/26/2007 11:38 PM | |
Posts: 7 Rating:
Hello! First You made mistake in MFLB number of CU cards (6SE…. not 6ES…). The second: 6SE7090-0XX84-0AB0 – this is the CUVC CLOSED-LOOP AND OPEN-LOOP CONTROL MODULE VECTOR CONTROL SIMOVERT MASTERDRIVES FIRMWARE VERSION: V3.4 The MFLB 6SE7090-0XX8-4AA1 – this is the number of part of CUFC drives with CU1 I send You links: 1. for the guidelines for changing over from the CU2 (not CU1, but could help) control module to CUVC: https://www.sea.siemens.com/drivesbu/support/startup-mc/cu2_cuvc%20guidelines.pdf 2. Link for manuals:https://www2.sea.siemens.com/Products/MotionControl/Drives/Vector-Control-Manuals.htm 3. Link of the CUFC and CUVC documentation.https://www.sea.siemens.com/drivesbu/support/startup-mc/Compendium%20Complete.pdf Hope of success |
