10/13/2014 9:44 AM | |
Joined: 8/23/2007 Last visit: 11/28/2023 Posts: 38 Rating: (4) |
Why don´t you use the ruler? I think it does what you want... You can activate the ruler in the "toolbar" of the online trend control, in order to see the values of the trends you have to insert a "ruler control" and connect it to the online trend control... The ruler allways open in a certain possition and you can´t possition it by program (https://support.automation.siemens.com/WW/llisapi.dll?func=cslib.csinfo&objId=23486416&load=treecontent&lang=en&siteid=cseus&aktprim=0&objaction=csview&extranet=standard&viewreg=WW) so operator should do this job... You can read out the values of the rule by program: https://support.automation.siemens.com/WW/llisapi.dll?aktprim=0&lang=en&referer=%2fWW%2f&func=cslib.csinfo&siteid=cseus&load=treecontent&groupid=4000003&extranet=standard&viewreg=WW&nodeid0=10805588&objaction=csview |
10/15/2014 8:55 AM | |
Posts: 72 Rating: (2) |
Thank you very much for your help, I knew it was a long shot anyways... |
8/6/2018 4:11 PM | |
Joined: 1/1/2017 Last visit: 6/19/2024 Posts: 330 Rating: (11) |
Hello! Presently I'm facing a similar issue. But the hyperlinks which have been posted here are not available or moved to new address! If possible kindly provide me the link as I'm facing the similar troublesomes right now. Regards OmKris |
