11/6/2014 10:04 AM | |
Joined: 2/21/2014 Last visit: 7/15/2024 Posts: 652 Rating:
Hi Sethi, If you want to make the script global, then you can create a global Action and assign a cyclic trigger to it. see attachment. If you want the script to be Faceplate specific then you can create cyclic script inside the faceplate. that script will be run (cyclically) only when the faceplate is opened in runtime. see the attachment. let me know if it helps or any problems. AttachmentC:\Users\ic011204\Desktop\Cyclic.zip (1490 Downloads) |
Last edited by: HarrY ji at: 11/6/2014 10:18 AMI don''t think it is possible to activate the script by a trigger( for ex. Tag value change event) and then run the script cyclic (e.g. every 1 min) You can always use "Rate" and "To Thank" button to appreciate my efforts in helping you :) |
