10/15/2010 11:23 AM | |
Joined: 1/4/2010 Last visit: 9/25/2024 Posts: 650 Rating: (40)
Hi This function execute the export data button: SetPropWord(lpszPictureName, "Control1", "ToolbarButtonClick", 20); Have a look in this FAQ: http://support.automation.siemens.com/WW/view/en/11769423 |
10/15/2010 2:09 PM | |
Posts: 1530 Rating: (59)
Hello Insausti, I also found an FAQ: 11831537 which seems to handle the same problem, but the solution is a little bit different from theFAQ Romulus suggested to you. So you will have two possibilities to solve your problem. Best regards Bizur |
10/21/2010 11:45 AM | |
Posts: 150 Rating: (2) |
I don't understand whatt you mean with the whole path, could you explain me the meaning of : @SCREEN @WIN12 @1001 @DESK |
10/21/2010 2:17 PM | |
Hello Insausti,
11868924FAQ: "Notes on WinCC object addressing", will be helpful for you, if you have to findout an object adress. |
