11/28/2018 7:34 AM | |
Posts: 4 Rating:
Hello Everyone, I have KTP1200 HMI and S7-1512C-1PN PLC project in TIA15. I have configured 15 archieve tags in HMI for trends.Also alarm log is created. I’m using smart client facility to access KTP1200 thorugh smartphone using VNC viewer. But if KTP1200 is accessed using smartphone then tag logging get stopped.As observed, table in trend window shows “###” sign in place of values.Also historical alarm window shows blank screen with clock sign in middle of window.Data logging again starts after restarting KTP1200.For data logging,I’m using USB storage of 32GB. Smartserver settings in KTP1200 are already applied and attached.Any other settings are required?? Could you please fix this problem or something is going wrong? Swapnil.J AttachmentSettings.zip (38 Downloads) |
11/28/2018 4:10 PM | |
Joined: 10/19/2005 Last visit: 11/30/2020 Posts: 1611 Rating:
Hey, did you have try this simatic apps => https://support.industry.siemens.com/cs/at/en/view/92275245 I mean, this should be work regards, |
11/28/2018 4:27 PM | |
Posts: 4 Rating:
From suggested applications I have used Simatic Lite application..but same problem noticed. |
