2/13/2012 6:09 PM | |
Posts: 204 Rating:
Hi all, I want to know are s7-1200 have data logging option like S7-200? and how can i get excel sheet with data recording from s7-1200 or any sheet ?? |
2/14/2012 4:17 PM | |
Joined: 9/23/2005 Last visit: 3/24/2023 Posts: 4180 Rating:
Hi, S7-1200 (actual version) has a Data log like S7-200. Take a look at the manual, chapter 8.7 Datalogging. You access (download) the .csv by the web interface. Take a look also at: Sample program: S7-1200 and DATA LOGhttps://www.automation.siemens.com/BR/tf/WW/en/Posts/57715#top |
Denilson Pegaia |
2/15/2012 12:35 PM | |
Posts: 12 Rating:
Hello Nashwa_459, Data Logging in S7-1200 is easely configured. For that, you only need to follow the sample program from Pegaia! Pegaia has given useful tips for data logging and you can find them here: /tf/WW/en/Posts/54367 To download data as CSV file, you shall enable the Web Server in your CPU module. To do that you shall go to CPU properties -> Tab Web server -> active the check box “Enable Web server on this module”. Then you just need to type in your web browser the IP of your CPU module! I hope that this information helps you! |
2/15/2012 4:38 PM | |
Posts: 204 Rating:
Thanks for you , i will try it |
