3/25/2011 2:51 AM | |
Posts: 65 Rating: (2) |
You can set it manually or take from your PG/PC. For that, in SETP7 v10.5 you can go CPU -> "Online and diagnostics". Then select "Functions -> Set time of day" item. There you can press "Apply" button to set up PLC date/time. If you have HMI, you can set up PLC date/time using your HMI. See an example here. |
