9/13/2012 12:57 PM | |
Posts: 8 Rating:
Require programming example for activating and deactivating DP slave devices with SFC 12. |
9/13/2012 1:04 PM | |
Joined: 9/27/2006 Last visit: 7/29/2024 Posts: 12272 Rating:
Hello Ashvita; Have a look at the following FAQ: How do you switch off (decouple) a slave without causing an error entry to appear in OB 86/ OB 122? Hope this helps,Daniel Chartier |
2 thankful Users |
9/13/2012 1:14 PM | |
Joined: 4/22/2010 Last visit: 5/3/2024 Posts: 5697 Rating:
Hello, Attached another example in pdf. Regards, Marcjan AttachmentFC3_dp.pdf (217 Downloads) |
Problem solved? |
3 thankful Users |
3/13/2018 1:47 PM | |
Joined: 6/19/2017 Last visit: 6/28/2024 Posts: 8176 Rating:
New question published by charlie87 is split to a separate thread with the subject CPU 315-2 PN/DP just stooped with no error announcment. Best regards |
