9/10/2008 7:39 PM | |
Posts: 4 Rating:
Is it possible to add a decimal separator on the diplay. I want to monitor a water meter with a pulse switch. Every 100 literi getan impuls. The display shouldhave a range from 0.0 to 9999.9 m³. Atached my current example Thanks for your assistance. AttachmentEnergiemeter.zip (584 Downloads) |
9/10/2008 9:03 PM | |
Joined: 1/5/2007 Last visit: 4/7/2023 Posts: 1690 Rating:
Hi Yvob, |
==> Meine TAG-Listen: "deut." |
9/11/2008 8:00 AM | |
Posts: 2930 Rating:
Hi, here is a proposal how to get your request solved: To change the display dig after the dezimal point change the properties of the analog MUX. I hope this helps. Regards Helmut AttachmentEnergiemeter.zip (554 Downloads) |
9/12/2008 10:56 PM | |
Hi yvob, AttachmentDEMO_big_value_with_komparator.zip (471 Downloads) |
9/18/2008 9:00 PM | |
Posts: 4 Rating:
Thanks I finaly Decided to use two displays. Now the range isOk and I can show decimals In the example I count 3 different items. Display 1: 999999 m³ Display 2: 0.999 m³ Display 3: Reset AttachmentEnergiemeter_Mux_06.zip (546 Downloads) |
