7/20/2015 1:42 PM | |
Joined: 5/30/2014 Last visit: 6/2/2023 Posts: 117 Rating:
Hi Denilson,
Aleksandar
Last edited by: Min_Moderator at: 7/20/2015 4:25:47 PMNew subject after splitting If you find my contribution helpful please RATE it :)) |
7/23/2015 8:40 AM | |
Joined: 1/28/2009 Last visit: 6/2/2023 Posts: 6803 Rating:
Hello, If you want to delete a DB from the online mode in TIA Portal, select the CPU-->right click-->Go online. In this view, you can see the whole blocks available in CPU.Select the DB you want-->right click-->Delete-->Delete from Device.In this case, the online version of DB will be deleted and a mismatch will be reported by color codes in TIA Portal.It is your decision to download the selected DB from offline mode again. I hope this helps, hdhosseini |
