4/18/2024 11:44 AM | |
Joined: 3/26/2024 Last visit: 5/8/2024 Posts: 3 Rating: (0) |
Hi everyone, Does anyone know how the user can put the comment in the Detailed log here? Best regards, AS |
4/21/2024 3:12 PM | |
Joined: 11/8/2017 Last visit: 5/15/2024 Posts: 318 Rating: (175)
Hi, This may or may not be what you're looking for, but you can manually add 'notes' to alarms / events when they are in the Alarm Viewer. In the alarm viewer, under the 'Information' column - you have the option to click the 'log an event note' button. Screen dump attached. You can then view the 'notes' that have been added to a point by adding the 'Action Details' column under the 'Detailed Log' tab (the same location you have in your screen dump). In my other screen dump, I have added a note that says 'TEST NOTE'. Regards, AttachmentCaptures.zip (8 Downloads) |
Last edited by: CJ. at: 04/21/2024 15:15:35Last edited by: CJ. at: 04/21/2024 15:17:10 |
