1/24/2023 1:47 PM | |
Joined: 6/4/2010 Last visit: 5/3/2024 Posts: 376 Rating: (126)
Dear forum member, You did not mention the firmware versions used on the devices. Anyway, I recommend updating the firmware to the current version if it should not already be in use yet. You can find the current firmware versions under the link below: https://support.industry.siemens.com/cs/us/en/view/109780759 I recommend contacting your local Siemens SI BP Customer Support in case the issue should persist. Best regards, Albis |
2/6/2023 8:39 AM | |
Joined: 4/12/2022 Last visit: 1/16/2024 Posts: 6 Rating: (0) |
I upgrade to FW_PXG3.WX00-2_V02.20.126.11-41 , But still not work |
