6/12/2010 4:26 PM | |
Posts: 26 Rating: (0) |
Hello, I am skimming SFC51 help but I do not find this SZL index (C119). Can you explain me the neccesary index and array size for this ID? Thanks |
6/12/2010 7:46 PM | |
Joined: 12/22/2006 Last visit: 1/25/2022 Posts: 1742 Rating: (308) |
Hello, In the manual http://support.automation.siemens.com/WW/view/en/1214574 at page 33-4 the composition of an SSID is described The list I would use is called xy19 (see chapter 33.10 x can have several values, where C (1100) means CP y can have the value 0 or 1 (see chapter 33.10) Final result is C119 Index seems not specified, I would tru value 0 The response should be 4 bytes per record. Content is described in chapter 33.10 |
6/13/2010 6:10 PM | |
Posts: 183 Rating: (8) |
Hello jklm; I think this list is only for CPU's not for CP's. |
6/21/2010 11:22 AM | |
Hi guys, I tried with this SZL_ID but it didn't work (error 8082). Any other ideas? Best regards |
