1/31/2020 4:13 PM | |
Posts: 174 Rating: (2) |
What is the advantage over programming in PCS7 than just Simatic S7 Tia portal. |
1/31/2020 4:39 PM | |
Joined: 9/27/2006 Last visit: 8/9/2024 Posts: 12275 Rating: (2680) |
Hello Jibin Mathiew; The subject you are broaching is quite extensive, and it would be easy to drown you in all the technical aspects of PCS 7 programming languages (CFC. SFC, SCL), integration of WinCC pages and alarms. monitoring and conditioning of digital and analog I/Os... but it is easier to bring up documentation from the provider and users. In the Siemens PCS 7 pages you will find many descriptions of the product, extolling its virtues and showing off its realizations. For example: https://new.siemens.com/global/en/products/automation/distributed-control-system/simatic-pcs-7.html The forum also has a great many threads on the subject: https://support.industry.siemens.com/cs/search?search=S7%20vs%20PCS%207&type=Forum&lc=en-US Here is a small contribution from another automation forum that gives a good idea of the programmer's point of view: http://www.plctalk.net/qanda/showthread.php?t=62534 If you are really interested in the PCS 7 programming environment, these training modules from Siemens could give you the basics: Hope this helps, |
Last edited by: dchartier at: 01/31/2020 16:44:42Last edited by: dchartier at: 01/31/2020 16:46:03Last edited by: dchartier at: 01/31/2020 17:06:06 |
