7/16/2009 4:28 PM | |
Joined: 1/5/2007 Last visit: 4/7/2023 Posts: 1690 Rating: (580)
Hi DIXEN51, please look here: AM2 PT100 °C precision I hope this helps you to connect your sensors right... Best regards Betel |
==> Meine TAG-Listen: "deut." |
7/16/2009 7:08 PM | |
Joined: 9/6/2008 Last visit: 3/29/2024 Posts: 134 Rating: (16) |
as Helmut said analog comparator maybe is the easiest way to do thiks like what you look for. and if you have a td 200 display then the "game began" to be very interest in the settings. best luck AttachmentLOGO!Soft Comfort - analog comparator test.pdf (687 Downloads) |
http://electrotech-techblogg.blogspot.gr/ |
6/28/2010 1:50 PM | |
Posts: 3 Rating: (0) |
Dos any one have i scren dump on how to make this in lad? Differencial thermostat for start blower at 5dg difference temp ? |
6/29/2010 11:46 AM | |
have a look at the pdf make your settings! AttachmentLOGO!Soft Comfort - analog comparator test.pdf (501 Downloads) |
6/30/2010 6:26 PM | |
[have some questions about some of the functions in the diagram. What do M3 and M4, F1, F2 and F3 do ?] from logo help ( m3-m4) Flag blocks output their input signal. LOGO! provides 27 digital flags M1 ... M27 and 6 analog flags AM1 ... AM6. The LOGO!TD module has four function keys that you can use as digital inputs in your circuit program. You program the function keys in the same way as other inputs in your circuit program. Function keys can save switches and inputs, and allow operator control of the circuit program. Attachmentanalog comparator test.zip (477 Downloads) |
