12/19/2012 12:31 PM | |
Joined: 9/27/2006 Last visit: 5/2/2024 Posts: 12257 Rating: (2666) |
Hello Mentor; One of the memorable starting points of my carrer in automation was a training for Step 7 and S7-300 PLCs ("S7 Programming level 2")presented by Sitrain (Siemens Training offices). So I will vouch for their usefulness and content, theoretical and practical. They are expensive, at first glance, but they are worth it. And the certificate in my resumé has helped to shed light on my technical competence in that area. Have a look at the presentation page for Sitrain Worldwide: https://sitrain.automation.siemens.com/sitrainworld/?AppLang=en Use the Worldmap to locate your country or the closest training center and look at the available courses. You will find content and schedule information in the following links. Note that for PCS 7 training you must look under the "DCS" or "Process Automation"tags, depending on the country's training center designation. Hope this helps., Daniel Chartier |
12/21/2012 10:59 AM | |
Posts: 836 Rating: (99)
Hi, check out the PCS 7 Langing page for some important and very uselfull topics: http://support.automation.siemens.com/WW/view/en/63481413 If you are interested in PCS 7 conform programming / engineering check out the PCS 7 Compendium wich you can find linked on this page. Whats your diploma about? More aboutProcess Controll System (including SCADA with OS Server, Clients, Archive Server, ...) or more about automation systems (just the "simple" I/O programmming, with diffenrt logics like timers, datablocks, FBs, FCs, ...). |
