6/23/2011 2:48 PM | |
Posts: 6 Rating:
Hi, Is it possible to monitor the alpsed time for an action (input or output) in Hours, minutes and seconds and display this on the TD? Thanks Sean |
6/23/2011 3:09 PM | |
Joined: 4/22/2010 Last visit: 5/3/2024 Posts: 5697 Rating:
Yes it is, by use offa async puls generator and a few counters. Maybe not that accurat. See example in attachment Regards, Marcjan Attachmentelapsed_time.zip (338 Downloads) |
Problem solved? |
7/1/2011 12:20 PM | |
Posts: 6 Rating:
Hi Marcjan, Thanks for example. I can use this for my application. Limiting factor now is how little the TD can display on one screen! Sean |
7/1/2011 4:59 PM | |
You can use a menu structure to show more on your display, there is an example here : |
Problem solved? |
