9/4/2023 8:43 AM | |
Joined: 8/3/2009 Last visit: 5/17/2024 Posts: 12970 Rating: (1650)
Hello kovaley I found a similar topic but without a real solution (LINK) Also here are some information about 64 bit values: https://support.industry.siemens.com/cs/ww/en/view/109738561 I did also a quick test (with the LReal) an I can simulatePLc and Comfort Panels and can also insert values < 0.5 to the IO Field and/orPLC block Bye Murof |
Last edited by: Murof at: 09/04/2023 09:17:11Last edited by: Murof at: 09/04/2023 09:46:34If this Information really helps, you could use the Rate function |
