7/15/2015 12:05 AM | |
Posts: 14 Rating: (0) |
Thanks for reply! good infromation You gave me. I have one more question, what if I want to have 70% of this value? not 50%. Best wishes John |
7/15/2015 4:46 AM | |
Joined: 10/7/2005 Last visit: 12/20/2024 Posts: 3029 Rating: (1058)
Hello johnyE assuming you have a 941-944 CPU, simply use the inbuilt Arithmetic Blocks of the 115U CPU, namely FB242 (16 bit multiplier) or FB243 (16 bit division). If it is a 945 CPU, you can use the inbuilt Arithmetic instructions. I suggest you have a look at the manual for your CPU which contains all the details on this. I hope this helps |
Cheers |
