5/30/2022 12:20 PM | |
Joined: 1/11/2019 Last visit: 10/7/2024 Posts: 764 Rating: (151)
Hello Zankkar, No need of separate license to configure the drives from PCS7, what all you need to do is install the Drive ES setup. It comes up with Drive ES PCS7 block library. You have to integrate/interconnect using these blocks in order to control the drive using PCS7. Kindly go through the below link to know more about drive block and there usage for the different Siemens drives(Eg: MicroMaster, Sinamics) I hope it helps you! |
