1/23/2023 2:39 PM | |
Joined: 8/3/2009 Last visit: 10/18/2024 Posts: 13982 Rating: (1760)
Hello GTSAGarcia if you work with WinCC flexible then the structure of the csv Files are explained in the help system: https://support.industry.siemens.com/cs/ww/en/view/18796010/1458951947 https://support.industry.siemens.com/cs/ww/en/view/18796010/1458469259 The structure is fixed and the same in each panels that uses this in this Version. Bye Murof |
