10/28/2014 9:28 AM | |
Joined: 3/20/2009 Last visit: 9/9/2024 Posts: 4 Rating: (0) |
Hello, I have exacly the same behavior in PCS7 environment. There are some solution for fix this issue? Thanks Miguel |
10/28/2014 2:42 PM | |
Posts: 1058 Rating: (93) |
Hello Endre, same issue has been discussed here, but without a solution as I see: Asi Link Maybe you should start a service request with Siemens. Do you use Object Manager? It helps a lot with properly integrating ASi devices. You will find download here: DP/AS-i F-Link: Object Manager OM F-Link for STEP 7 regards |
