2/19/2010 1:40 PM | |
Joined: 3/21/2006 Last visit: 4/25/2024 Posts: 10228 Rating:
Hello KevinC, I suggest you to check everything according instructions' manual DP/DP Coupler (chapter 4). How did you assigned set the PROFIBUS address? Via DIL swithes or with hardware configuration. Important is to check possition of this DIL swiches. Isn't possible to attach here your hardware configuration? This would helps. Best regards, Hristo Mihalev |
