2/3/2016 6:44 PM | |
Posts: 20 Rating: (0) |
please help me. i need the driver of the USB PPI multi master cable with S/N:6ES7 901-3DB30-0XA0 waiting for your response best regards basim ------------------------------------------------------------------------------------------ |
Last edited by: Min_Moderator at: 2/4/2016 9:49:45 AMNew subject after splitting |
8/30/2016 12:20 PM | |
Posts: 1 Rating: (0) |
I also failed configuring same USB PPI MM cable for MicroWin 4.0 SP9 Witch adaptor is to be selected? How to configure widow PG/PC Interface ? |
12/12/2016 8:40 AM | |
Hi!, Same problem for me as described from my colleagues (see attached pdf file) STEP 7/Micro/Win V4.0.9.25 Microsystems Communications V1.0.9.25 PG/PC Setup in Control Panel is 32 bits!!!! and we are running on a 64 bits machine, could it be the problem??? Thanks, Javier AttachmentMicroWin PG_PC interface problem.pdf (3540 Downloads) |
Last edited by: JavierLuque at: 12/12/2016 8:43:18 AMLast edited by: JavierLuque at: 12/12/2016 8:55:19 AM |
