3/26/2014 2:28 PM | |
Posts: 12 Rating:
Thanks for the quick reply but I have already installed drives es 5.5 sp1 with step 7 5.5 SR 3 on another pc. |
3/26/2014 2:35 PM | |
Joined: 5/12/2006 Last visit: 8/13/2024 Posts: 22342 Rating:
Hello, here you find the compatibility list. If you installed a constellation which ist not supported then good luck You can try the following: Install DriveES without Starter after the sucessfull installation you can install Starter seperatly or use the newest Starter Version , which doesn't need Drive ES . Regards Christoph |
