4/8/2024 2:34 PM | |
Joined: 4/8/2024 Last visit: 5/17/2024 Posts: 8 Rating: (0) |
Good morning, I would like to bother you because I would like to know if anyone can help me with my problem. I am brand new to WinCC Unified and I am trying to move a group (I/O field, text box, button) using the view that I display on the view window below, but I cannot do it, I tried the "Screen.Names", "Scren.Number"...Here's a picture of the window I'm using. If you can help me I will be grateful Guillaume
AttachmentDessin sans titre.pdf (125 Downloads) |
Last edited by: Jen_Moderator at: 04/09/2024 07:11:15Headline translated. Last edited by: AutoGen_1517992 at: 04/09/2024 07:26:31 |
4/8/2024 7:45 PM | |
Joined: 1/21/2013 Last visit: 9/27/2024 Posts: 3139 Rating: (489)
Hi Guillaume, This is an English forum. So please try to use English here.
To be honest, I have no idea what you want. Your screenshot shows a screen that appears to contain 3 windows. You cannot put anything into a screen window other than a screen. A screen can contain various elements such as IO fields, text areas, buttons, or other screen windows, which in turn contain a screen. This is the so-called screen-in-screen functionality of WinCC Unified. For more help, you should be more specific. Kind regards |
4/9/2024 8:28 AM | |
Hi Guillaume, Thanks for your clarification. So as far as I understand, you want to display a group of items on the screen that is visible in your header when a particular screen (syn_vireur) is displayed in your main screen window. To access items on any screen, you should use the 'FindItem' method. Let's say you want to access the text box containing the text "REF:" and this item is named "txtRef", you should use Screen.FindItem("~/Entête/txtRef") to access this item. To conditionally display a group of items, I would group them at the desired location and dynamically change their visibility. That way, I would only need to access the group, not each individual item. This can be done in the OnLoaded and OnUnloaded events of your screen (syn_vireur), or you can use the change event of the 'ScreenName property of your header screen window (Entête_ScreenName_OnPropertyChanged). I hope I named your screen elements correctly, the text in your PDF document is not very legible. Kind regards |
