12/22/2020 3:08 PM | |||||||
Joined: 9/27/2006 Last visit: 4/27/2024 Posts: 12257 Rating: (2665)
Hello Milind; It is not quite enough to look for a certificate by category, you must know what standard the certification is based on. For example: - S7-400 Modulle data- EMC certification https://support.industry.siemens.com/cs/ca/en/view/1117740/82228051723 EMC directive SIMATIC products are designed for industrial applications. Table: Use in industry
- S7-400 Module data- RFI certification https://support.industry.siemens.com/cs/ca/en/view/1117740/82228051723 Emission of radio frequency interference Emissions from electromagnetic fields in accordance with EN 61000-6-4. Emissions over main AC supply in accordance with 61000-6-4. Once you have these standards designation (EN 61000, in this case for example), and if you require a copy of the certification document in addition to the manual above, you can either search the Product support pages for S7-400/Certificates (using the search box at the top right of this page), or you can ask directly the Siemens techs, through a Support Request (there is a direct link at the top center of this page). Hope this helps, Daniel Chartier |
