4/26/2024 11:30 AM | |
Joined: 3/14/2008 Last visit: 7/11/2024 Posts: 2075 Rating:
Hi, Please execute a Save as with reorganization (slow) for the multiproject. You can reach it via Simatic Manager->File->Save as. If it does not help it could be an installation issue, you may also try to use the APL demo project and try to compile. If it succeeds, it's a project issue. |
