8/18/2022 7:40 PM | |
Posts: 1 Rating:
Hi everyone! I'm trying to connect S7 1511T-1PN to MindSphere via LMindConn_MQTT on TIA V17 and I ended up here looking for an answer to error 16#8601, which I assume is similar to LMQTT. Here follows the diagnostics: status: 16#8601 https://support.industry.siemens.com/cs/ww/en/view/109772284 With Best Regards, Vinicius D'Agosto ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 08/19/2022 11:19:15New subject after splitting Last edited by: Jen_Moderator at: 08/19/2022 11:21:33Link optimized. |
9/8/2022 11:02 AM | |
Joined: 4/8/2013 Last visit: 7/3/2024 Posts: 72 Rating:
Hi Vinicius, You should check the documentation of the library for the status codes: Status 16#8601 means that LMQTT_Client threw an error and its status code is output at subfunctionStatus. Status 16#8620 means a timeout occurred. I would guess the PLC has no internet connection or the host name is wrong. |
9/12/2022 11:04 AM | |
Joined: 8/3/2009 Last visit: 8/2/2024 Posts: 13443 Rating:
Hello check the application examples to this topic: https://support.industry.siemens.com/cs/de/en/view/109772284 https://support.industry.siemens.com/cs/de/en/view/109748872 Bye Murof |
