7/26/2016 3:29 PM | |
Posts: 73 Rating:
Thank you for your reply. SQL 2014 was part of the installation, but in the services I saw the SQL server was starting and seemed to run OK. Although, 'SQL server agent' was disabled. Even when I set it to start in SQL server configuration management, it will automatically disable itself. Would you suggest that I install SQL 2014 express from the top |
