7/5/2023 7:35 PM | |
Joined: 12/14/2022 Last visit: 7/19/2023 Posts: 1 Rating:
I'm trying to onboard an IoT2050 to send data to Insights Hub. Using the MindConnect node in Node-Red. But I am getting this error related to the MindConnect node: node: AgentConnectNode msg : error "Error: Network error occured Bad Request {"error":"invalid_grant","error_description":"[f24407e9ece742f1adc378c115340db4]"} (hint: possible cause for this error is invalid date/time on the device) see also:https://opensource.mindsphere.io/docs/mindconnect-nodejs/troubleshooting.html" I set the date/time of the IoT2050 manually, using "Siemens Industrial OS initial System Setup" Many thanks! |
