2/9/2015 2:22 PM | |
Posts: 6 Rating: (0) |
Hi When I download (Change Only) but happened system Error like the attached .. Would you please help me ?
AttachmentError_message.txt (61 Downloads) |
2/9/2015 2:24 PM | |
Hi This is the 2nd attchment for the former question ... Please check this again. |
2/11/2015 8:27 AM | |
Posts: 567 Rating: (106) |
Hi,
I think the problem with the report has nothing to do with the CFC/SFC problems.
Do you use the standard reports or customized? If you use customized does it work with the standard? The batch report topic is a very complex one so I would suggest you to open a service request at the Siemens technical support. Also for the CFC/SFC problem. I think in this case there something wrong with the installation but I'm not sure . Here the link for opening a service request: https://support.industry.siemens.com/sc/de/en/sc/2090
Good luck |
