10/9/2009 9:42 AM | |
Joined: 4/5/2006 Last visit: 4/24/2024 Posts: 917 Rating: (63) |
Hi Delphoe , i sees you are trying to install SP1 for SQL2005 when get error. SP1 is over a different a DVD than SQL2005; did you installed SQL before trying to install SP1 ? If yes, try to look how long is your "path" lenght enviorment variable and if you are using all lenght (My computer properties -> Enviormant variable). If everything is okies, can you post a screenshot of SW installed from SIAMTIC menu and from Windows Control Panel? Regards |
