6/1/2022 5:12 PM | |
Joined: 9/27/2006 Last visit: 9/10/2024 Posts: 12282 Rating:
Hello Arian-A; Thre is a lot of information here on PCS 7 and licensing, you will have to learn to navigate Product Support if you want the answers to al your questions. Use the search box at the right of this page for more information. First, PCS 7 distinguishes ES (Engineering station, here you develop your program), AS (the controllers, S7-400 stations, where the program fro the ES is run) and OS (operatiing stations, WinCC PCs where the ES program for visualisation is run) So an E-SW is a software that is installed and run in the ES. The attached document in ths link shows differences between different license types (for WnCC, in this case, but they apply to all Siemens automation products) that are used throughout Siemens catalogs, see the attached screenshot. - What information is available about licenses for WinCC (TIA Portal)? https://support.industry.siemens.com/cs/ww/en/view/74796111 A runtime license is required when you need to run a F-systems or WinCC program, for example, developed on the ES, in your AS or OS system. These documents will show you more information on F-systems, PCS 7 archiving licenses and AS/OS Engineering licensing: - S7 F Systems V6.2 Released for Delivery https://support.industry.siemens.com/cs/ww/en/view/109740650 - What should you watch out for when using archive licenses with SIMATIC PCS 7? https://support.industry.siemens.com/cs/ww/en/view/108893968 - How are the licenses for the AS and OS counted in PCS 7 V7.0 onwards? https://support.industry.siemens.com/cs/ww/en/view/38855207 Hope this helps, Daniel Chartier |
Last edited by: dchartier at: 06/01/2022 17:16:56Last edited by: dchartier at: 06/02/2022 01:17:57 |
4 thankful Users |
6/4/2022 2:11 AM | |
Joined: 9/16/2021 Last visit: 1/6/2024 Posts: 45 Rating:
Hi dear Dchartier, i understood and so much thanks for clear explanation dude. with best wishes |
