5/19/2012 8:33 PM | |
Posts: 95 Rating:
what is target share? and what is the name of OS? Someone helps please. |
5/19/2012 8:43 PM | |
Joined: 3/18/2008 Last visit: 12/8/2023 Posts: 1750 Rating:
What should you watch out for when downloading from the WinCC Engineering Station to the WinCC Operator Station (ES-OS download)? please check this out. |
VANDE MATARAM..... |
5/19/2012 10:25 PM | |
Posts: 95 Rating:
Thank you, but I already checked. My problem is when selecting the shared folder, the error pops up. Anyone had this problem before? Best regards |
5/20/2012 12:23 AM | |
Joined: 11/4/2011 Last visit: 7/22/2024 Posts: 253 Rating:
Hello AlecTek, yes, I have had this problem. All you need When you wrote \\Esos1\OS\OS.mcp you specified a target share as "OS". The classical way is to share a folder named "Project" and then your path would be: \\Esos1\Project\OS\OS.mcp But the \\Esos1\Project\Project\Project.mcp again would be wrong And the main conclusion: That error message is wrong! It should say: The name of the target share should not match the name of the OS |
