1/19/2017 5:49 PM | |
Posts: 2 Rating:
Hi all, We are using a DeltaV system with ET200iSP (DI, AO) - have established communications, all appears fine. No diagnostics LED's showing any issue on ET200 However, when we force a discrete input for example - we are getting no switching on the channel. Similarly, in setting a AO value, there is no activity on the relevant channel. When we initially powered up the unit, we were unable to pick up anything on our profibus loop, but that was resolved by some sort of factory reset any ideas? Thanks in advance ------------------------------------------------------------------------------------------ |
Last edited by: Min_Moderator at: 1/20/2017 12:53:02 PMNew subject after splitting |
