6/24/2008 10:37 AM | |||
Joined: 9/27/2006 Last visit: 7/13/2024 Posts: 12268 Rating:
Hello Iam; This is what your part number refers to:
It is a commercial number that allows you tio buy as a single unit the IM 153-2s and the busmodule. In your hardware configuration you need to use the part number that you find on the IM 153-2 (6ES7 153-2BA02-xxxx). Check at the bottom of the front door to the IM 153-2 to make sure. Hope this helps, Daniel Chartier |
