9/5/2014 11:25 AM | |
Posts: 24 Rating:
Hi Pittiplatsch, Please find the attached ZIP folder containing all the necessary images to answer your above questions. One point though- earlier the error that was showing in 1215C Diagnostic Status was of Error in Lower Level Components. As the ET200SP module was communicating with the PLC (even though with the Error LED ON), I didn't bother to check the status again. Now when I went online again to take the screenshot, I noticed the error in the 1215C Diagnostic Buffer changed to "Error on Partner-Wrong Partner Port). I have attached a screenshot of my Topology View too so that you get an idea how the system is connected. Currently, in order for me to go online from the PC, I have disconnected PLC2 connection from Port 2. ET200SP is connected to the Port 1, while I am Online from the PC through Port 2. Do let me knoiw if you need any further details for the same. Thanks, Parshva
AttachmentET200SP Error LED Problem.zip (700 Downloads) |
1/22/2016 10:30 AM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4767 Rating:
New question published by nagadevan.k is split to a separate thread with the subject How to set IP address for IM155 modules in TIA V13. Best regards |
